Media session doesn't update when switching between tracks with same album art ID
The media session metadata doesn’t update when switching between tracks with the same album art ID as returned from Navidrome’s API (like tracks in the same album without embedded album art). Logs were complaining about recycled sources in createBitmap.
Navidrome
  • Start playing album that matches issue description
  • Switch to next track
  • Note that the notification still displays first track
Degoogled RisingOS 7.0, based on Android 15. Tested on existing install and on fresh install within a work profile, unfortunately did not have a second device available for testing. Also spun up a fresh Navidrome instance with an affected album and two unaffected albums (one with the same album art in each track, one with different album art per track) - access info available on request.
adamski2003-20260613
Duplicate and fixed in beta.
Unfortunately couldn’t find the post this is the duplicate of. I did just install the latest beta though, and it does, in fact, work. Thanks for the quick response!
