Hello @Tolriq please help me, my player can not display anything.
It’s says “ nothing to display”
Hi, what media provider are you using? Is that just offline files, music on your phone?
Hi, was wondering if you updated to the beta version? If so, there is an ongoing discussion at: Cannot add/change folders in local media provider - #6 by Tolriq
Media provider just for offline music
Good. I had something similar, I’m also using the offline music only.
Have you re-added the local device in the “manage media providers” option?
I don’t really know what to suggest, because I don’t know your situation. But if you already have it there, I’d delete it and add it again.
Then once you deleted it, you can add it back, then add permission to it and it’s seems to work for me
OK let me give it a shot, thanks
OK so here’s the thing, I’ve used this player for 2 years now.
Today, my local files just disappeared and it can’t scan them back.
Am from uploading my logs, hopefully @Tolriq will also come in
Sure, it’s the same for me. But I got it working somehow, hopefully you can do the same.
