Max skipped songs in connection error
I want to be able to set a maximum of skips when failing to play a remote song.
Sometimes my VPN, which I use to connect to jellyfin, and the app starts skipping songs trying to find one that plays.
I would like to be able to limit that, say if it skips 3 songs back to back then stop skipping and wait for a while.
Multiple songs skipped due to temporary connection error
Not missing multiple songs
There’s different cases for skipping and different limits.
Please provide logs and details about your actual use case.
Hi
I think I’m facing the similar “issue”: when I plug my mobile in my car, Android Auto starts way before I’m out of my garage (where I have no network connectivity).
What logs would you need and how should I retrieve them for you?
