I would love to be able to enable offline caching for a randomly sorted playlist with a max item count limit in place. It would be also fine for me to add a stable random playlist sorting (If you ask me, fixing the seed of the random function in this case should already suffice, we are not hunting any cryptographic goals with playlists anyway).
If I create a smart playlist, and select random sorting and N as max item count. When enabling auto offline cache, this leads to downloading all songs matching the criteria, instead of only N.
Pretty great to have a couple random rule based tracks available on the go.
Not provided
Not provided
