Just allow for maybe 2 or 3 more on the slider; purely cosmetic.
This could help especially with LANDSCAPE view on phones / tablets.
It’s just a cosmetic thing. Maybe someone wants small columns on a grid.
Other application solutions
Foobar2000 allows for this, when using EOLE theme.
Just curious… if you need that many items to show, why not just use Row instead? It fills in the items a little differently, but at the end of the day it looks about the same.
Below is a pic of regular row at the smallest size. Multi-line style is available as well, if you want the Grid look.
Didn’t know about this!!! Thanks for the idea!
Main difference is that Grid shrinks items to fit the screen, whereas Row stays at a set size and scrolls instead.
Idk if that makes a difference for you.
Can’t find ROW, its under Display Mode right?
Sorry, could you tell me where to go to change it? I’m a bit lost in the settings xD
My fault, I assumed you were talking about on the Home page. If your request is for media pages (like Library → Albums), currently there is no Row option.
