Hi there and thanks for the great app symfonium.
I’m using symfonium V 6.0.0 (1148) in addition with navidrome music server (V. 0.49.3) to play mostly my music in *.m4a format at my android smartphone (Android 13, Kernel 5.4.210). Playing music works fine. But it seems to be impossible to play lyrics on *.m4a-files. When playing my music with the embedded “LYRICS” tag (synced lyrics) in the navidrome web UI, then all plays fine. When playing the same files at symfonium than the lyrics works only with *.mp3-files. The lyric button doesn’t show up while playing *.m4a-files.
Again: at navidrome web UI it works with both (*.mp3 and *.m4a) and it seems to be supported to use embedded lyrics with navidromes api. So i was aking if i can configure anything for work with symfonium.
For the attached logs, I’ve disabled local cache und cleared the same. Then I synchronised navidrome in symfonium and search for the test title “Megaherz - Falsche Götter”. The first file is the version in *.m4a (with embedded synchronised lyrics). The music played fine but without lyrics. After that I played the same version as *.mp3 (again with embedded synchronised lyrics) and the lyric-button appeared instantly and works fine.
Unfortunately 80% of my music is coded in *.m4a and i don’t want to recode them. So maybe there is anything else i could do?
Thanks for checking.
debug-20231109_114039.zip (4,1 MB)
Unfortunatelyi can only add one attachment (as new user) so the post was refused with additional screenshots.
Navidrome is installed containerized (in version 0.49.3) at an mini linux home server running at debian 6.1 and docker-compose.
