My music files that have embedded lyrics. Some of them have an external lyrics file (which Jellyfin can parse and return it via API).
I have noticed that those have external lyrics file are shown as synced lyrics in the app and the timestamp of every lines are all set to 00:00.
I checked the API response from Jellyfin and it does not add any timestamp.
Upload description: joshuaavalon
Example of response JSON.
"Metadata": {},
"Lyrics": [
"Text": "\u611B\u304A\u3057\u3044\u65E5\u3005\u3092\u3000\u523B\u307F\u3053\u3093\u3060amulet"
"Text": "in my precious days"
"Text": ""
"Text": "\u9752\u3044\u9CE5\u304C\u9003\u3052\u51FA\u3057\u305F\u3068"
"Text": "\u7A7A(\u304B\u3089)\u306E\u7C60\u3092\u62B1\u3044\u3066\u3000\u6CE3\u3044\u305F"
"Text": "\u3042\u306E\u65E5\u898B\u4E0A\u3052\u305F\u3000\u9AD8\u3044\u7A7A\u306E\u8272\u3092"
"Text": "\u3044\u307E\u3067\u3082\u899A\u3048\u3066\u308B"
"Text": ""
"Text": "\u5DFB\u304D\u623B\u3057\u305F\u3000\u60F3\u3044\u51FA\u306E\u4E2D"
"Text": "\u304F\u308B\u3057\u3044\u3068\u304D\u306B\u3000\u3057\u3042\u308F\u305B\u306A\u65E5\u3005\u306B"
"Text": "\u5927\u5207\u306A\u5834\u9762\u306B\u306F\u3000\u3042\u306A\u305F\u304C\u3044\u305F\u306E"
"Text": ""
"Text": "\u8FF7\u8DEF\u306E\u679C\u3066\u307E\u3067\u3000\u3055\u304C\u3057\u3066\u3044\u305F\u3082\u306E\u306F\u3000\u80F8\u306E\u5965\u306B"
"Text": "\u3084\u308F\u3089\u304B\u306A \u5BC6\u3084\u304B\u306A\u3000\u8A18\u61B6\u306E\u304B\u3051\u3089"
"Text": "\u3069\u3093\u306A\u660E\u65E5\u3078\u3082\u3000\u6B69\u3044\u3066\u3086\u3051\u308B\u306E\u3088"
"Text": ""
"Text": "\u91D1\u306E\u9396\u3067\u7E4B\u304C\u308C\u305F"
"Text": "\u53E4\u3044\u3055\u3073\u3057\u3044\u65CB\u5F8B\u306F"
"Text": "\u3042\u306E\u65E5\u8FF7\u3063\u305F\u3000\u6DF1\u3044\u68EE\u306E\u5965\u306B"
"Text": "\u305D\u3063\u3068\u7F6E\u3044\u3066\u6765\u305F\u306E"
"Text": ""
"Text": "\u3042\u306A\u305F\u304C\u3044\u308B\u3000\u305F\u3060\u305D\u308C\u3060\u3051\u3067"
"Text": "\u308F\u305F\u3057\u306F\u3044\u3064\u3082\u3000\u5F37\u304F\u306A\u308C\u308B\u306E\u3088"
"Text": "\u4F55\u5EA6\u3067\u3082\u3055\u3055\u3084\u304F\u308F\u3000\u512A\u3057\u3044\u30E1\u30ED\u30C7\u30A3\u30FC"
"Text": ""
"Text": "\u8FF7\u8DEF\u306E\u679C\u3066\u307E\u3067\u3000\u3055\u304C\u3057\u3066\u3044\u305F\u3082\u306E\u306F\u3000\u3053\u3053\u306B\u3042\u308B\u306E"
"Text": "\u3044\u3064\u3067\u3082\u8F1D\u304F\u3000\u308F\u305F\u3057\u3060\u3051\u306Eamulet"
"Text": "\u6CE3\u304D\u305D\u3046\u306A\u591C\u3082\u3000\u3061\u304B\u3089\u3092\u304F\u308C\u308B\u306E\u3088"
"Text": ""
"Text": "\u99C6\u3051\u629C\u3051\u305F\u65E5\u3005\u3092\u3000\u523B\u307F\u3053\u3093\u3060amulet"
"Text": ""
