I’d like to see 2 changes, that could also be tested to see if the community appreciates these changes or not.
1: Remove the animation from the translated lyrics.
Why? They do not contain word by word syncing.
2: Change the colour of the translated lyrics to the one that the normal lyrics have.
Why? Since these lyrics can only be translations, the user shouldn’t be confused by the same (or almost same) colour, since the 2 texts are on different line and most importantly, are in 2 different languages
Having animations that do not serve any other purpose other than looking pretty isn’t useful.
The colour is just my bit for absolute Apple Music dominance, even if I actually think it looks better with white text, or something close to white.
Less animations, less load on the phone?
I’d happily show what Apple Music does with synced lyrics and translations, but I’m not from the US, so no translations for me.
I’d also like to propose to make the translations smaller than the main lyrics.
That helps cause:
1: Sometimes, Japanese lyrics that have english translations are painfully long, so that would help keeping the lyrics in view.
2: This is the standard that Apple Music uses.
In addition, I’d like for any LRC Lyric to also have the translation text in a smaller font.
This is the format that I currently use (since Symfonium respects newlines)
[time] Translated Lyric
Original Lyric
Example:
[00:01.05] So many times we’ve waved to each other
横断歩道の向こうとこっち側
The screenshot has “pronunciation” turned on, and that is synced in the ttml file. The translation are synced on a Line by Line format. This does make sense, as the pronunciation is probably generated with the original lyric, making it easier to sync it.
The translations can’t be synced word by word, since they use a different language.
I’d like for the translations to be a tad smaller then, Apple Music made so you can clearly see the difference in font size. That would also help differenciate the translation from the original lyrics.
As I probably said in another post, the different colour is something I strongly disagree with. You can make it out, even if a music had the same alphabet (and the smaller text was implemented)
You posted at the same time but this is inverted … The English is the source the other is the translation in LRC format. (If you use the same timestamp) else it’s not a translation it’s a multi line text …
[00:01.05] 横断歩道の向こうとこっち側
Thanks, I hope you’ll at least try for a (Beta) version the proposed changes. I’ll try to supply some translated lyrics and original lyrics that use the same alphabet.
