Lyric freeze problem
Beta
While scrolling the lyrics to a song, the lyric page will randomly stop responding to swipes or taps (swiping the lyric screen downward during these times will end up closing the now playing screen instead of scrolling. And tapping any lyric wont actually play that part of the song like it usually does, instead it just wont respond).
  1. Play any kind of song
  2. Go to the ‘Now Playing’ screen
  3. Open the lyrics
  4. Swipe either direction
  5. Notice how it’ll randomly freeze (noticed its most common when reaching the top/bottom of the lyrics)
jay677 - Lyric freezing issue
Could you record the next time the lyrics stop responding? Start just before opening the lyrics, scroll until it happens, then tap a timed line and show the downward swipe that closes Now Playing. Upload the clip at https://upload.symfonium.app and add a short description so I can find it.
If you remember roughly when it happened in the logs you already uploaded, please tell me the time. The log shows a seek that matches a lyric line, but it doesn’t show which part of the screen handled the swipes.
Just uploaded a clip of it happening. And gave it the description “Lyrics freezing during scroll/tap” if that helps
For the record in the clip you click lyrics when paused, this does not unpause the music in Symfonium by design.
I’m aware of that, but even while paused it will still highlight that lyric when tapped. It doesn’t do that in the clip
Same issue here.
Uploaded a log as Celorien_LyricsScroll with a matching video as Celorien_LyricsScroll_Video.mp4
