The album covers for my music files show up as pixelated low quality files, when most of my music had the highest quality available.
I already have the “High quality images” option enabled, but they still look kinda bad
Upload description: samvargu
Your logs is empty
Please provide those images and details about them. But for your phone to have a perfect image your source image should be 1980*1980.
This is one of the images, but both images are 2000x2000 and definitely shouldn’t look as pixelated. I think maybe it is cause that’s the background and not the cover? I suppose you maybe render them differently.
Also sorry about the log file lol, I legit made it after this asked me to make one
This gives
for me.
Are you sure you do not have a lower quality version of the image in the tags or multiple version of the image ?
Weird, and I’m sure cause it doesn’t only happen with those 2
The drawing and the letters should be sharp, but they look pixelated.
Is there maybe a setting I’m missing to make it work apart from the “high quality images” one? Or to reload the cached images to see if that’s the problem
Hum yes you should clear image cache in advanced settings if you enabled the setting after all images where already cached.
Omfg that was it, I cleared the cache and now they look sharp, thanks!
