The following clips will show the issues
Upload description: zyntaxyz low quality album covers
I can provide more examples and files if needs
I uploaded two clips showing the issues (with their description) and two m4a files as I used in the clips, a video is worth a thousand words right?
Enable hi res images in the logs and clear image cache.
This page?
Both issues still there, I’ll upload the log with hi res images enabled
Edit: log uploaded
With hi res images there’s no possible image degradation unless Gonic does it (As said be sure to have clear the image cache).
The other issue you see is because when opening the detailed page a higher resolution image is loaded in memory cache and then reused for the smaller lists. Unfortunately the images specific granular type and ultra hi res makes Android image filter generate the small artifacts. Not much I can do for that part without wayy too much side effects on all users.
Gonic? The music server right? I’m not getting, I’m a local provider user
and yup, I tried clearing image cache multiple times (including after enabling hi res images) and even reinstalling symfonium but here we are
I guess I can live with those weird artifacts…
