I’m not sure if this is possible, but since it is a Feature I’ve utilized and enjoy with Plexamp I am making the request.
What would that do ?
There’s replay gain support maybe that’s what you mean and just need to enable it?
I’ll need to research this.
So the way I understand loudness leveling to function in Plexamp is that the listening volume will be boosted or lowered so that when changing from track to track the volume level change won’t be jarring. Is this what the replay gain does?
Yes replay gain adjust each track / album volume based on the values present in the tags.
So does this fit your need or is there something missing ?
Yes, it resolves. Thanks.
