Long Time to load smart filter
I have an album smart filter based on one playlist that has 3593 tracks in it.
It takes about 30 seconds to load. All the other filters based on path and genre load instantly.
The provider is pcloud (there is no option for pcloud when creating this issue so I used webdav)
The playlist was originally imported so I tried playing it and then saving it as a new symfonium playlist but it makes no difference.
Upload description: r5yk5_debug.log
WebDAV
You can try to go to advanced settings then press cleanup internal state that might help.
That sorted it.
Thanks :slight_smile:
