Allow a long-press on a single library in the global filter menu for faster enabling/disabling libraries of the same media provider.
Two cases:
If the long-pressed library is not enabled or if there are currently other enabled libraries, the long-pressed library will be set as enabled. All other libraries will become disabled.
If the long-pressed library is the only one currently enabled, the filter is inverted: the long-pressed library becomes disabled and all other libraries become enabled.
With a lot of libraries it is cumbersome to only enable a single library from a media provider. The more libraries you have the more effort is needed to only select a single one.
Anybody with a lot of libraries will profit, as it would allow fast switching between single libraries also when there are a lot of libraries.
In my case there is a library for each family member and for some specific purposes like Audiobooks or language learning.
