Long loading times and buffering during playback
Songs usually take a very long time to load and most songs usually end up buffering during playback. However if I add a song to offline cache the whole song is downloaded almost instantly. I’ve tried messing around with different cache settings and sizes. Other clients such as the web client load quickly and don’t buffer.
Music is in ogg vorbis format being streamed from Navidrome.
From the logs (that you did not say you uploaded :wink: ) seems the proxy closes the connections.
You can check the proxy logs, and in playback/advanced enable force HTTP/1.1 to workaround some proxy bugs.
Hello, sorry about the logs. I’ve connected to my server through Lan and am now using VPN to connect through Lan to listen while I’m out of the house. So far no issues. Thank you. (:
