Long buffering delay (5-10s) with FLAC playback
Hello, I am experiencing a consistent 5-10 second delay before playback starts, but this only happens with Hi-Res FLAC files. Standard MP3s play 1-2 sec.
Environment:
  • App Version: Latest
  • Device: Google Pixel 7
  • Android Version: Android 16
  • Server: Navidrome
  • Network: Local 5GHz Wi-Fi (Excellent signal), Server is on Gigabit LAN. Bandwidth is definitely not an issue.
The Issue:
  • MP3 (320kbps): takes about 1-2 sec
  • FLAC (24bit / 96kHz, ~3300 kbps): Takes about 5-10 seconds of buffering/loading before audio starts.
Troubleshooting steps taken:
  • Direct Play confirmed: I checked the Navidrome dashboard during the delay. No transcoding is happening on the server side.
  • Comparison: The same FLAC file plays instantly via “Feishin” client on the same network.
I have attached the debug logs where I reproduced the issue with a Hi-Res FLAC file. Could you please help me understand what causes this delay?
Thanks!
Upload description: Carotis_Interna
Disable the transcoding engine in the settings and ask Deluan to support the transcoding OpenSubsonic API.
