I’ve been using this app for a week now and I love it. However, there is one thing that bothers me, which is the inconsistency between the pages with the items, as shown in the screenshot.
The pixels in the screenshot are not entirely accurate, but they clarify the issue.
Why do you suggest Test V14 in beta? Does it contain specific fixes for this alignment issue?
Edit: I read the changelog, will check it out, thank you.
Edit 2: I’ve tested V14, but unfortunately, the alignment issue persists and cannot be changed. I really hope this can be addressed in a future update.
Also, while the content is configurable, the spacing here isn’t. Since I can’t adjust margins manually, shouldn’t the app ensure they are consistent across all screens?"
“The home is a special cases due to the titles and all the special stuff.”
I can understand.
“With that said if you find differences on similar pages in v14, please report them precisely.”
I did find differences in v14 as well, but I realized that it is not specific to the pages, but rather the view types. The “List” view seems to differ from all the rest (Landscape overlay, Grid, Grid card, etc.).
So here a precisely report with a few examples:
(the red lines indicate the differences in distance between the display modes)
Actually that’s more your instructions that I need
See for example the 2 requests that are similar :
The problem is that since everything is configurable in Symfonium and the primary color is already possibly used in the page, I can’t just take the primary color and apply it as background / overlay.
Need to figure out the kind of colors that won’t kill the eyes to extract that still ensure that the primary color can be seen and primary container and all the texts.
So this is a mix of color selection and accessibility. I find some of the examples in the second case making the text unreadable, and for the first the color is way too flashy, specially for a dark theme, I’ve seen tons of complains about the apple addition of that full color background.
