Beta
I’m finishing my Now Playing layout and I’m stuck on two landscape issues. Screenshots of both orientations are attached.
Blank strip where the camera hole is
When the camera cutout is on the left, the artwork starts about 140px in and leaves an empty strip down the left side. When I rotate the phone the other way (cutout on the right, behind the controls), the artwork sits flush to the left edge. So it isn’t a cover art margin. Something is still reserving the cutout area, even though I have Symfonium set to ignore camera holes. -
Artwork stops short of the bottom
There’s roughly a 60px band below the artwork that matches the gesture bar. The cover art is square and seems to be sized to the height left after that inset, so it never reaches the bottom edge.
3.Side overlays on the cover art in landscape mode. Only gives top, bottom and full. Ability to recreate the blue overlay in landscape as seen in portrait image attached.
Subsonic (Open)
Ignore camera holes enabled in Symfonium
Cover Art Margin(s) set to 0 in the landscape expanded player
Force-stopped and reopened after each change
Phone is a Xiaomi 17 ultra
archaleas
