Symfonium UI has gotten really laggy and there seems to be a lot of stutters.
Upload description: xcuze - lag_new
I have uploaded a screen capture of this issue, with the filename “xcuze - lag.mp4”
Any provider
Are you sure you have enough background apps running on that device? The number of things in the status bar is amazing.
Anyway the logs does not really show anything. Can you try to reboot the phone first then report back with Beta 3 when it’s out with more logs navigating in the app.
The recent beta update seems to have resolved it.
