Keyboard auto Popping
Before the new 1.30 update, whenever i used to open one of the tabs (albums, artists or playlists), nothing would pop and it was fine, but after the update, whenever i open one of them, it just auto pops my keyboard and it becomes really annoying when you check multiple albums/artists/playlists. im not sure if it’s meant to be this way or a bug, but i hope y’all make it into a feature
Upload description: Keyboard Auto Popping
  1. open one of the tabs
Already reported and fixed.
what does fixed mean? because i was talking about this 1.30 update release, i know the guy in the form also aksed the same thing but I don’t which update you or him meant. sorry for the duplicate
Fixed to me means the dev has fixed the issue in the code and it will be available with the next update.
And you can see what is the current version from here, so the the next update will be 13.0.1 or something like that.
