Jump to now playing track in playlist
When viewing a currently playing queue, if I scroll away from the track that’s currently playing, a button appears that I can click to bring that track back into view. Can that button also be added for playlists?
Sometimes I want to remove a currently playing track or its album from my playlist, but I have to either slowly scroll through the entire playlist to find it, or use the filtering options (which apparently causes unrelated issues with deletions, as mentioned in a previous thread).
A “jump to now playing” button in playlists like there is in Queues would be more convenient. Plus consistency of behaviour across the app, having it available everywhere it’s viable rather than only in Queues.
Just use the filter as it was fixed.
OK. When you said it would be fixed, I wasn’t sure if the fix you mentioned would make it possible to delete while filtering, because it also sounded like it wasn’t possible. (i.e. the “fix” being not giving delete the option while filtering)
