Dear Support,
I just started using your software today, and found a bug.
This one can very easily be reproduced by yourself that if you create a library in Jellyfin server use the catagory of “books”, it will be displayed in Symfonium by mistake. Could you please help to fix it?
Thanks.
Upload description: No log needed for this one, very easy to reproduce
Create a books library in Jellyfin, then add the Jellyfin server into symfonium.
