Jellyfin Auth Error with correct info
I redownloaded symfonium and wanted to log into my remote Jellyfin instance. I passed it the correct information but it displays a error stating i have provided it the wrong username or password.
Upload description: gm_blahaj
Logging in with other Clients works flawlessly
There is a nginx in front at that URL that requires an auth during the ssl tests (that remove the last /)
Can you tweak the nginx conf to work for that url?
I’ll check when back from holidays why the test is done without the last / breaking your proxy conf.
<head><title>401 Authorization Required</title></head>
<body>
<center><h1>401 Authorization Required</h1></center>
<hr><center>nginx</center>
</body>
</html>
You probably moved on, but it will be fixed in next release.
Thanks, had a slight mental health problem
