It collect songs in different subfolder to the same folder level
I split 30 songs (They belong to same album) into 4 subfolders by disc number. However, these files are all displayed at the same folder level, rather than being sorted into their respective subfolders.
1.add jellyfin url
2.tap folder view
3.select jellyfin
4.tap a music lib
5.tap the folder
6.show these songs instead of 4 subfolders
I find the same problem in feishin(a windows jellyfin music player),but I can’t find folder view function in jellyfin.I cheaked the api of jellyfin and it shows the correct path.So I think there may be a wrong logic in player.
Thanks.
None
The app displays the data that Jellyfin sends via it’s API.
