Sorry for the repost(?) It appears as though the forum combined an old report that I didn’t finish writing and I didn’t notice.
I have noticed almost on a daily basis that at some point when using Symfonium, I won’t be able to select a song that I want to play. I will tap the song, and instead a song below will be highlighted and start playing.
The first few times that I encountered the issue, it seemed to specifically select the song directly under the one I wanted, but this morning it selected the song that was two spots down.
Sometimes it will pull up the media screen (the screen with controls and album art), other times it won’t. I’m not sure what causes that behavior.
Closing and opening the app appears to resolve the issue immediately, although it also seems to go away on its own, but that might be a result of me not interacting with the music list much after starting my playlist.
I initially thought the issue was my fault- that I was maybe holding my phone at an odd angle and couldn’t see where I was tapping, since I am usually in a hurry walking while setting up my music.
However after it happened a few more times, I realize it is an issue with the app
Upload description: cmayk
I don’t have local music, I use Navidrome to stream my music to Symfonium.
Since I mostly use the “Favorite Songs” list, I have only observed the issue there.
I listen to music through the night, and the app gets interrupted by my alarm clock in the morning, I’ve known this to cause trouble with apps in the past.
I haven’t identified any steps to replicate the issue.
