Issue regarding filter button
On Android TV box, when the filter button is not in hidden mode (Settings-Interface-Advanced settings), it is impossible to browse the music catalogue, as the selection only goes from the menu bar on the left, to the filter button on the right. When the filter button is in hidden mode, everything is ok. But I need the filter button to be visible, in order to launch the sync with my local NAS.
Thank you in advance for your support.
Upload description: Federico
Yes that’s why it’s not enabled by default on Android TV.
It’s really annoying that TV users have to do this turnaround to sync, every time a new album is added to the local lan library.
The button is visible in home and there’s sync manager. You never need that button there.
