Internet radio pause and rewind
Add the ability to pause, rewind, or fast forward internet radio stations back to the last 30 minutes or 1 hour. Maybe even have it done for all internet radio stations that are saved in symfonium.
Commercials. Many internet radio stations have commercials. If I have the ability to pause for a while, let’s say when I take a potty break, then when I come back there is some buffer saved, if a commercial comes up I can then fast forward past it.
If this is done for all stations once I open the app its even better. I wouldn’t even have to take a potty break, I would be able to switch stations and check back if there was a song I liked in the last hour if a commercial happened to be playing right then.
I think I explained this already above. This would bring a lot of value to the app for me particularly since I listen to a lot of internet radio with this app.
My car radio buffers the actual radio for the last 20 minutes or so. But the buffered content gets erased once I change stations. I’d really love if it didn’t erase though and saved for all of my preset stations.
Sorry way too complicated to maintain.
What kind of maintenance would be needed? I’m not a software developer but this seems like a feature that once implemented will keep working without updates. Also, I know there’s already some kind of pausing happening when I get a phone call while listening to a station. I just want the ability to go back and forth within whatever that cache is, and maybe increase the cache size.
