Intermittent disconnection with pCloud
Symfonium disconnects intermittenly from a pCloud provider although the cloud is alive. It will eventually connect and then disconnect.
In addition, it consumed mobile data while syncing, although I checked the “Wifi only” setting in the media provider section. It happened when my phone lost connection to WiFi.
I know the pCloud support is experimental but please sort this out.
Upload description: Intermittent disconnection with pCloud
The log uploaded has a description pCloud-issue-20241229
  • Add pCloud to media providers
  • Add a folder in pCloud to inclusion list. This folder should have a lot of folder and music files.
  • Sync the media provider using the filter feature
Any provider
Cloud providers connection status is based on network status. So if you enable Wifi only and have some wifi disconnect then the provider is offline.
The WiFi connection was fine, but it was detected as offline. Restarting the app would reconnect and enable sync. I uploaded the debug.log.
And it shows the wifi was not ok.
Please provide a normal size log only showing this.
I have uploaded a log that was enabled since the issue happened until after I restarted the app.
