You are correct, the issue is slightly different than topic, sorry
And you have any idea on what is causing the issue then?
Been searching on Pixel Phone Help as well, but didn’t seem to come across people having same issue.
The only thing I can see is that you send the play command before the phone have switched to BT, maybe the OS intercept that and decide it should keep using the active output at the moment of the play command.
The actual play command is handled by Symfonium after the phone have already rolled back to the phone output, so it’s not even Symfonium trying to output sound that triggers that.
Ok, thanks for your swift responses, really appreciate it!
Next time I’ll try to wait a little time longer before tapping earplugs after I’ve put them in again.
