More control over happens when a certain device is connected.
Example devices
- Bluetooth Headphones
- Car
- Gaming headphones
- Sleep headphones
- Cast speakers
Example options
- Autoplay on/off
- Load Eq DSP
- Load playlist
- Shuffle on/ off
- etc
Great app BTW!
You want autoplay for your car but not your headphones.
Your car uses a different eq preset.
Gaming headphones won’t want autoplay
Sleep headphones might want a particular playlist
Fantastic automation!
Probably called
‘Connected Device overrides’ or similar
Add connected device button which then appears in a list so you can alter it’s settings
Thanks
