inconsistent icons
Some of the icons are inconsistent.
Some icons are different for the same function depending on where in the UI you’re looking.
Example:
Add to playlist in the expanded player is different to add to playlist within the “more actions” menu within the expanded player.
Some functions share the same icon with each other for different functions.
For example:
Add to playlist in the expanded music player/add to queue
Start radio mix / internet radios
Upload description: debug.log
Thanks the add to playlist in now playing is a copy paste error.
Actually this is because also of a duplicate icon to show the current queue :frowning:
For duplicate icons, well I’m limited to Google icons and it’s hard to find variations for all the needs.
Ah yes, it seems '“current queue” is using the same icon as the ‘correct’ “add to playlist” button uses. It certainly works how it is, but would be amazing if you could manage to get some more icons somehow. Would make it more usable for new/less techy users. For people who host servers with multiple users.
Would like to take the opportunity to tell you how amazing this app is. Things like this make me excited about the future of tech and software again, and how it could develop. Thank you very much!
Found another icon discrepancy. The radio mix within the expanded player is different to the one within “more actions”
See image:
Another duplicate with smart queue / flow :wink:
Haha yes, I just noticed that. :sunny: It uses the same icon as the internet radio / radio mix. I remember noticing that months ago but just ignored it. Would you need someone to contribute with additional icons for this to be fixed?
Yes it needs contributors but it is very complicated to reach perfect harmony with the already provided icon set by Google and the parameters chosen. That’s why I do not add some random icons taken outside the set.
