Inconsistancy of buttons design
As it’s not really a bug, I’m not sure about the category. This is about the color design of buttons across the interface, which vary depending of the page.
  • On the settings, the icon of a button have the same color than the outline (so blue in my screenshots).
  • On the now playing queue, the icon have the same color than the text (so white here).
  • On the “sync” button, the text have the same color than the outline (so blue).
You can’t choose a color settings which create consistancy, unless you use the same color for the outline and text.
I think it would be good to harmonize those buttons. It make sense to have a “primary button” design, and a “secondary button” one, but various secondary button design doesn’t make sense to me.
  1. Open symfonium
  2. Choose an accent color different than the main text
Ottodix
There’s chips, outlined button over background and over primary container.
The chips design is on purpose as it’s a different function than normal button it’s a component with actions, buttons are too big.
Ok. For the user, i’m not sure that the different functions are understood, they both do actions in the end.
The buttons icon which sometimes is the same color than the text (on the queue for ex), and sometimes the same color than the outline (on the settings for ex), it’s on purpose also?
Something different: on the now playing queue, it looks like the playing track highlighting use the same color than the button outline. Using a different color setting would make sense, imho
