If I brought It using VPN via GooglePlay
This software is fantastic! I’m planning to purchase it, but I have a concern:
I installed it via Google Play using a VPN. If I use the same method to purchase it, will I be periodically unactivated when the VPN is Shutted? (no one connected to a VPN 24*7, right?) Does this APP conduct its verification through Google Play servers, or have its own independent servers that can be reach by in China?
[Please excuse that I’m in a region where everyone cannot connect to Google Play normally but VPN.]
Or Ko-Fi licences is better in my situation?
这个软件太棒了! 我准备购买它,但是有点担心:
我是启用vpn后通过googleplay安装本软件的,如果我依然使用这个方法购买它,那么当我不启用vpn时(毕竟没人24H×7连通VPN吧?),是否会被每月定期踢除?这个软件的定期验证是通过googleplay服务器,还是有自己独立的服务器可在中国地区被连接?
[请原谅我这边地区无法通过正常手段连接googleplay,只能使用vpn。]
又或者Ko-Fi注册会更适合我的情况?
The license is managed by Google so if the Play Store no more says you have a licence there’s no check to do and no access.
Probably safer to use Kofi.
