Hello, I think it would be very useful if you can add the option to edit the ID3 tags for each file directly inside the Symfonium app. It is one of the few features that are missing in your great app. Thank you.
If the ID3 tags are missing or they are not correct, at the moment the user is forced to edit them outside your app because it doesn’t have an integrated ID3 tag editor.
Edit or add ID3 tags for each file directly inside Symfonium app.
