emaen
September 22, 2024, 2:35pm
1
Hello !
Not really a bug… but :
In the quick navigation top bar, only the filter icon use the active color scheme !
The two others icons (Home and Setting) keep been black.
Upload description: emaen Blacknotpink.jpg
Tolriq
September 22, 2024, 3:08pm
2
This is normal the filter icon only gets the primary colors when a filter is active so that’s it’s more visible. Same the settings buttons turns red and rotate when debug mode is on.
There’s no need to add more emphasis in the other cases.
emaen
September 22, 2024, 3:30pm
3
CitationThere’s no need to add more emphasis in the other cases.’
You’re right there is no need for that… I just think it “break” a little bit the design and the visual unit of the interface.
I may be the only one !
Tolriq
September 22, 2024, 3:43pm
4
If you do not enable a filter then there’s no color
If you enable a filter and there’s no color then you forget and open an issue because some things are not visible.
