I’m using AMO-RED style and noticed that there is that setting, how do I set it?
Edit: I use navidrome as media provider
Hey, that’s mine! ![]()
They’re just Smart Playlists that you add to the Home Page. If you go back to the theme page, I have a “Playlist setup” section showing you how to make the playlists.
Once that’s done, in the playlist, open the menu and “Add to Home page.” Then go to Settings > Interface > Home page. Edit the playlist the (SP) Suggested _____ that matches , scroll to the bottom, and “Change playlist” to the ones you just made. Done.
