How to disable? I would like to remove them.
Upload description: sameasiteverwas
Use a tagging tool to remove them?
I could, but I don’t have use for lyrics anywho; is there a way to disable?
No there’s not it’s just a button don’t click it.
It’s that it shows on the cover and it can be annoying.
Settings>now playing screens>expanded now playing>overlay icons visibility
Toggle that to less visible
That should be less of an intrusion on your album art especially when music is playing.
Then you could use a program like mp3tag to quickly remove any embeded lyrics (in batch) although I’d suggest getting the correct lyrics its kinda nice, especially synced ones IMO
