Using the size “Extra small” in the predefined playlists in homepage is not working as expected.
Everytime I use “Extra Small”, the items show as “Normal” size.
Upload description: Row Grid Size Issue
- Go to Settings > Interface > Home Page
- Go to the config of any of the predefined playlists, for instance: Recently Added Artists
- Set Style: Row (Grid)
- Set Size: Extral Small, you can immediately see in the Preview panel that items are bigger than the Small size, (screenshots attached).
- Go to the actual home page and you will see the same problem, the items seem to have the same size for Normal items (screenshot attached).
