It would be handy, when going in the search tab, that the previous search would be highlighted so you could search something else directly instead of hitting the clear button or deleting the previous search with the keyboard.
The need to clear the previous search (which is almost every time in my use case)
Yes, but when you narrow the search, you stay on search page.
Whereas if you were to go on the search page later on, it’s often to search something else right?
