Help finding raw artist tags
Hey, just hoping someone could point me to where the new “raw artist tag” option is in the settings? Also, if possible, an example of what it is supposed to look like pre and post selecting it. Thanks!
Upload description: Not applicable
In the provider settings and it will display the artist tag as the displayArtist mostly exactly as the option and the changelog says :wink:
Sorry, is it only certain providers? I don’t see it here under a subsonic provider.
Yes it was said before it’s for the providers where Symfonium actually have access to the tags.
So LMS currently doesn’t provide access to this information?
As said Symfonium displays the data that LMS sends.
See with @itm for details about displayArtists
Hello! What do you want to check with these raw tags?
You can use the lms-metadata tool to parse a file and see how it is interpreted by lms.
Synfonium added the ability to display raw artist titles in their latest update. But it only works if the backend provides that as an option.
