I installed the spotie theme from the official site and it didn’t fit my vibe. Now I want to change it but for god’s sake can’t find the settings menu. The below is the SS of the app:
Would be really helpful if anyone can help. Reinstalling the app isn’t an option as I cache my entire library. Reinstalling the entire library isn’t a task in looking forward to.
Thank you in advance
Thank you!! Now I can finally change it. But this feels as if it was hidden intentionally. It would be better if it was much more intuitive than this.
It probably was hidden intentionally
Once you’re all set up, there’s not too much need to have a big Settings button in your face. But as far as sharing the theme publicly, yeah it might be wise if the designer made it more visible.
Alternatively, they may just have a wider screen than us. Who’s to say?
Anyway, happy to help.
