Grouping tag not appearing
When viewing the track details the “grouping” field does not appear, and when viewing the album grouping tab of the library or using the grouping smart filter set to “is present” no tracks appear.
Navidrome
1: Search for a track with the “GROUPING” or “CONTENTGROUP” tag
2: Click the three dots, then click details
3: Observe that no grouping field appears
I have both the “GROUPING” and “CONTENTGROUP” tags populated, and they appear normally on my desktop client. They also show up when searching the uploaded log.
To reproduce the issue for logs I used the track “Funk Goes On 極”, it should be the last item played.
I apologise if I’m missing something.
ArtieF - Grouping tag not appearing
Yes it’s a very recent addition to OpenSubsonic not yet added on Symfonium side, will do for next release.
Ah I see, thank you for the help!
