Gonic - Opus transcoding not seekable
I am running Gonic on my home server (Alpine). I recently enabled transcoding to Opus 64 to save some mobile data when traveling. The music is streaming fine, but I am unable to seek when the song is playing. I tried increasing the cache for Gonic to 512 Mb, but I have had no luck. What could I be possibly missing? Is this a limitation of Gonic? Are people using other servers like Navidrome facing similar issues? Loving Symfonium so far. I only wish the seeking function worked :slight_smile:
Subsonic (Open)
Open music folder and select any track. It starts playing. When I seek to a specific time in the song nothing happens.
I can make the log available if someone could guide me on retriving it.
Probably not :wink:
Those 2 does not match, and the wizard tells you exactly how to :wink:
Anyway you must not force transcoding server side but must do it in Symfonium settings.
Hi Tolriq. That was quick. Thank you for getting back to me. If I disable transcoding on the server side and select 128 or any other bitrate on Symfonium, I get playback error and then a message saying stopping play or something like that (Error playing media, ensure that your player support it). The other support thread has some reference to github about adding new transcoding extension; hence I started a new thread :slight_smile: Do you have any advice on what other settings I may be missing in Symfonium? Thank you again for your time and patience.
I tried using epoupon / lms (Lightweight Music Server) and it looks like I am able to transcode and seek files. Seeking seems to have a lag, but it works :slight_smile:
