Be sure to read the following link for how to gather logs.
https://support.symfonik.app/t/how-to-gather-logs/18
Any issue without the logs can be automatically closed without any further notice.
- Add as much details as possible, including reproduction steps.
I have 4x Albums that are tagged with Genre of “80s” but they are appearing as “[Missing Genre]” all music is Local Device and tagged correctly with just ID3v2.3 tags and I’ve done a Sync
- Join files do not paste the content of the files here !
debug-20220502_181257.zip (2.1 KB)
Symfonium: 1.0.0-600 Android: 11 - 30 [arm64-v8a,armeabi-v7a,armeabi]
Device: samsung - SM-A505FN [a50eea - a50]
Symfonium displays the data returned by Android and does not directly parse the tags.
I need logs during a full sync to see the data returned by Android but you probably need to force a rescan like with https://play.google.com/store/apps/details?id=com.house.noranuko.mediarescanner&hl=en&gl=US.
debug-20220502_200738.zip (630.6 KB)
Here is a full rescan log, it doesn’t seem to identify a genre of “80s” though other music apps are seeing it correctly. I’ll have a go with the rescan tool and see if I can make any difference
Thanks
As said Symfonium relies on Android and does not have it’s own parser.
Can you send me one of those songs in PM so I can see what stock Android gives on it ?
Ok so can confirm stock pixel also does not return a genre for that song / album.
This sounds like a stupid Android bug because it start with a number. Can you try to rename the genre tag to something that start with a letter and see if that fix it?
Edit: And tested with other players that does not have their own scanner and they all behave the same
