Gapless while skipping songs
To remove the silence between songs while skipping
next song takes longer to star playing
next song starts to play faster
works perfectly on feishin while accessing my flac files on the same device, but not on offline files on symfonium
I use opus transoced for offline files. Also here is a video of the silence between songs : https://www.youtube.com/shorts/5fCf8OWQDKs?feature=share . Did I miss a setting or is this a limitation of offline/opus files?
Disable the fades in the transition settings. But the next song needs to be loaded.
Thanks for the quick answer, sadly settings the fades to disabled has no effect on it. How do I load the next song? or are you saying that my phone takes the time to load the next song?
The problem was opus, changing the transcoding format to aac makes it a lot faster but not perfectly gapless.
