@xxxms Thank you so much for your help. It looks amazing, and it’s a feature I’ve been requesting for a while. You’re creating a fantastic theme. Tolriq adds so many things in this update, and it’s understandable that not everything works perfectly.
Hopefully, I can improve and optimize it for better compatibility and smoother performance. Even so, everything @Tolriq does is incredible…
It was built on 14.0.0B7, you’re still probably using the old, stable release, so it doesn’t have the new features and isn’t able to apply the changes correctly.
Those are smart playlists, so you have to create them manually, you can find the rules I used in posts below. I’m afraid that’s how it works, the styles don’t have an option to copy the playlist too, I guess only thier placement on the home page
Great theme thank you! Making a few tweaks at the moment, not sure if im loosing it but the option to use gestures (tap to pause play, double tap to fast forward 30 seconds etc) is missing form the Now Playing settings? Any ideas?
Hi Archaleas. You can change it in your settings. I’m using lyrics on tap, toggle favorite on double tap and more options on long click, but you’re saying your twicking it for yourself, so you can easily change it in the now playing settings.
Thanks @xxxms that’s very kind forr you to offer. I have realised that the changes I have made included making the album artwork full screen (not to dissimilar to the photo attached, not mine) and by doing so that disables the cover art and with it the gesture options. Not sure if there is a way to have gestures with this type of layout
