Force display artist instead of using list-based Artists field
I use OpenSubsonic/lms.
Add a toggle which, for a song, always shows the displayArtist field as the artist even if it differs from the artists list. This allows adding arbitrary artists (such as remixers or producers) to a track (which then shows the track in their discography too), without the display artist being replaced with a comma-separated list.
I like adding remixers to the list of artists (‘artists’ tag = ‘artists’ array in Subsonic) in songs, so that remixes appear in the discography of the remixer.
However, I do not change the ‘artist’ tag (i.e., display artist, ‘displayArtist’ in Subsonic) expecting that it would keep the original display.
I’d expect that Symfonium show the display artist, and not a comma-separated list if it differs. Adding a toggle to force the display artist, while still retaining the click-the-field-to-show-all-artists-list, would work better for me.
A clean displayed artist field, with support for further customization of which Artist pages the track shows up in (for example, having remixes show up in the tracks by the remixer artist).
I feel like displayArtist should always be respected rather than defaulting to a comma-separated field if it differs. At least, it should be an option, I think.
Screenshots explaination:
  1. This track has displayArtist ‘Exteria’ but artists ‘[‘Exteria’, ‘V0iD’]’ (simplified). It should respect the displayArtist…
  2. …While still keeping the click-to-show artists menu with all the artists.
Symfonium displays the displayArtist value returned by the server by default.
You can use custom strings with the rules you want to display whatever you want.
This might be a bug in my server’s implementation - I’ll double check. Sorry for the bogus report!!
