Hello - I use two libraries:
- Navidrome for boxset/multiple disc releases
- Jellyfin for single disc releases
I want to use Navidrome for boxsets because it supports the Disc Subtitle tag, which allows for easy organising.
In my experience these libraries save offline cache files differently:
- Navidrome saves files to simple Artist/Album/Track # - Title structures, whereas
- Jellyfin saves this to Artist/Album/Disc/Track # - Title structure
When playing multiple disc releases from offline cache, Symfonium will often play the wrong file, as the only folder structure info available is Artist/Album/Track # - Track name.
This means that if a track shares the same Track # and Track name, even across different discs, Navidrome does not have the ability to parse which track is requested, and therefore plays the wrong track.
This would allow for further multi-disc release support, and would incentivise users with large collections (esp. of multi-disc releases) to use Symfonium.
Please see below screenshots for additional context. It would be ideal if Symfonium could set a consistent format for the API call to ffmpeg (or similar transcoders), but understand if that’s not possible.
