Floating theme removes navigation to settings
trying the new themes. go to settings-interface-change style and select floating.
unless you make sure to update the navigation beforehand, the option for settings is removed and I have to uninstall/reinstall the app to get it back.
Upload description: unable to properly upload logs since bug prevents navigation back to settings to end logging tool
My guy… Did you try scrolling to the bottom of the page?
well that certainly fixes the issue!
