In the new floating bar implementation, selecting the bottom option for the progress bar causes it to turn black for certain songs, resulting in low contrast against dark backgrounds.
To improve visibility, the progress bar color should dynamically adjust based on the floating player background. For darker backgrounds, it should switch to white or the text color for better contrast.
Upload description: xcuze_floatingplayer
Round progress bar works fine though.
Any provider
